TwinTurbo.NET: Nissan 300ZX forum - One factor - increased workload
Subject One factor - increased workload
Posted by bliZard on June 16, 2008 at 8:52 AM
  This message has been viewed 152 times.
In Reply To injector question posted by 2T-Z on June 14, 2008 at 10:24 PM
Message the best explanation for this that I have seen is that the A/F ratio is controlled by pulsing the injectors as a bank (right/left) - if one injector goes, the O2 sensor sees a lean condition on that bank and the ECU increases the fuel flow on the bank that the problem is occurring on. This makes the remaining injectors work harder (2 injectors trying to supply what 3 are supposed to) and makes the 2 working cylinders run rich.
So, you take injectors with 100k miles on them, then start making them work even harder when one fails, and their failure rate increases. The lesson I took from this is to get failed injectors fixed quickly.
